Ansys Learning Forum Forums Discuss Simulation General Mechanical Error Solving Semi Elliptical Crack Reply To: Error Solving Semi Elliptical Crack
ashish.khemka
Translated: I am currently doing my Master's Thesis using the ANSYS tool. Specifically, I'm using Static Structural analysis. I have a geometry that simulates a tooth with a fairly uneven surface and I'm trying to create a crack with the Semi Elliptical Crack tool and then look at those analyses. The tool generates the crack, but when I click on SOLVE to calculate the system and show me some results, this error jumps out in the solution information. Why could it be exactly, or how could I see what the problem is more clearly to fix it? Would there be any way to fix it?
