Ansys Learning Forum Forums Discuss Simulation Fluids ventilation louvres – enclosure – porous replacement Reply To: ventilation louvres – enclosure – porous replacement
udvardyszabokrisztian
Thanks! I thought of doing a simulation of the geometry of the louvres and seeing how the pressure and velocity change (difference between the inlet and outlet side) develops when projected onto a plane. After that, I would express the value of ALFA and C2 from an equation. The thickness of the porous region is equal to the width of the louvres (thickness). This is correct?
