Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Workbench LS-Dyna MAT_JOHNSON_COOK material model issue › Reply To: Workbench LS-Dyna MAT_JOHNSON_COOK material model issue
May 27, 2024 at 1:40 pm
Ram Gopisetti
Hi,Â
I am not sure if you have an ALE Domain set in your LSDYNA WB model.Â
This ALE Domain will set the surrounding mesh so that the fill material can flow in it.Â
I guess this should fix the issue. MAT_JOHNSON_COOK and *EOS_GRUNEISEN are now directly supported in the newer versions.Â
Cheers, RamÂ
