Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Temperature values on a path using APDL › Reply To: Temperature values on a path using APDL
Lydia Lymperopoulou
.Have you checked  documentation article 7.2.4 Mapping results into a Path 7.2. Reviewing Results in POST1 (ansys.com)?
Also this documentation link has an example that uses PATH commands: 3.4. Example Thermal-Stress Analysis (ansys.com)
This is the specific part I 'm reffering to:
! Define path by location
ppath,2,,.6
pdef,temp,temp
! Interpret temperature to path
pasave,radial,filea
! Save path to an external file
plpath,temp
! Plot temperature solution
