Ansys Learning Forum Forums Discuss Simulation General Mechanical Problem with artificial intervertebral disc Reply To: Problem with artificial intervertebral disc
Jorge Carames
Hello.
Thanks for your reply. I have created two frictionless contacts. If I solve the problem supressing the top body and applying the force directly in the hiperelastic, it works properly (image 1). However, if I try to solve applying the force in the top body to compress the rest of the piece, I get an error "An internal solution magnitude limit was exceeded" (image 2). I suppose the problem is in this contact. How can i fix it?
  Image 1
Image 2
