Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › airflow valve problem with solids › Reply To: airflow valve problem with solids
Devendra Badgujar
Hi Kasper,
Try setting it to standard global settings and increase the fidelity from the slider below to maximum. Looks like the valve is not getting captured and so the flow is passing through it. You can use it as as a Cutter bodies instead and assign a Local fidelity (BETA option) if you are using the 2024.1 version.
Try solving it with above suggestions and let me know if that helps.
Devendra
