Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Transient Structural Failure Analysis for a Low Tension Dead End Clamp › Reply To: Transient Structural Failure Analysis for a Low Tension Dead End Clamp
May 27, 2024 at 7:06 am
My static friction coefficient is 0.36. I calculated that myself using the pieces I have available at hand.
Regarding the displacement, how do I apply displacement gradually? I know that the UTM functioned under the setting of guarenteeing 5mm/min of displacement by varying the load magnitude as the piece deformed.
The UTM was able to achieve failure after 8 minutes.
