Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › crating structure mash from danse to undens in ansys mashing › Reply To: crating structure mash from danse to undens in ansys mashing
May 27, 2024 at 6:46 am
Keyur Kanade
After detaching if you want conformal mesh then you will need to use Share Topology in Design Modeler or SpaceClaim and then bring it in meshing.Â
Please go through help manual for more detailsÂ
If you do not use share option then you will need to use non conformal approach in fluent. You will need to define interface for those faces and proceed.Â
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
