Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Shaft analysis with SKF Bearing extension › Reply To: Shaft analysis with SKF Bearing extension
adam.berggren
Hi Dave and thanks for your reply.
I have tried using a remote displacement on the end of the shaft locking rotation and movement about the X axis. However, the results i recieve seems very unrealistic. A maximum equivalent stress of 5MPa with an applied torque of around 5700Nm. Is there potentially something else I could have missed?
BR
