Ansys Learning Forum Forums Discuss Simulation Fluids Possible to Integrate UDF source terms into FLUENT MHD module Reply To: Possible to Integrate UDF source terms into FLUENT MHD module
zoelle.wong
I see. I can append source terms into the model with MHD module turned on, but I'm not sure how to couple the source terms to the built-in MHD modules.
You mentioned coupling Fluent and Maxwell, what are best practices that you recommend to reduce computational runtime? For instane, for every 1 Fluent simulation is it faster to simulate Maxwell for 5 iterations? I understand this tends to be application based, but am curious about your input regarding mesh refinement and temporal resolution.Â
