Ansys Learning Forum Forums Discuss Simulation Electronics Simulating CPS (coplanar stripline) hfss Reply To: Simulating CPS (coplanar stripline) hfss
kirthika
Hi Chinmayi
I tried the port size as recommended in the HFSS port excitation document. It did not correlate with a published work and another software.
I used 5 to 10 times the height of the substrate 100um and the port was too narrow for very thin line widths.
Could you recommend the port size for a 6um width and 4um spacing coplanar lines on 100um substrate?
