Ansys Learning Forum Forums Discuss Simulation 3D Design change lineweight in SpaceClaim Reply To: change lineweight in SpaceClaim
Devendra Badgujar
Hello Lee,
Make sure that the type of object you want to have thick lineweight actually has the Thick value assigned to it. Most likely you want Visible edges to have the thick value. See the attached image:
If you want your default changes to apply for all new documents, you have to switch the options to apply to All New Documents.
Note: selecting All New Documents will not apply the changes to the current document, it will only apply to any new design you create.
Devendra
