Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Transient Structural Failure Analysis for a Low Tension Dead End Clamp › Reply To: Transient Structural Failure Analysis for a Low Tension Dead End Clamp
May 24, 2024 at 3:08 pm
This type "stick/slip" analysis is usually done with a gradually applied displacement, not an applied force. The reaction force at the applied displacement provides the force deflection information. The failure load is going to be somewhat dependent on the coefficient of friction between the wedge and the clamp. What value did you use for that?
