Ansys Learning Forum Forums Discuss Simulation General Mechanical Shaft analysis with SKF Bearing extension Reply To: Shaft analysis with SKF Bearing extension
dlooman
Bearings only constrain the lateral motion of the shaft, not torsion or axial displacement.  You could constrain those directions with a Displacement constraint somewhere or translational and torsional springs.
