Ansys Learning Forum Forums Discuss Simulation LS Dyna Import mesh to LS-dyna Reply To: Import mesh to LS-dyna
Armin
Hi Dmytro,
You don’t need another software for meshing. Once you meshed the model in Workbench LS-DYNA, select Write Input File (screenshot below), save the *.k file. Then when you open it in PrePost, there are some additional keyword files that are present as well but you can simply delete them in PrePost using the Keyword Manager (check also the image below).
