Ansys Learning Forum Forums Discuss Simulation LS Dyna Hydrostatic Equillibrium and material deformation in S-ALE FSI Reply To: Hydrostatic Equillibrium and material deformation in S-ALE FSI
Abhemanyu Palaniswamy Chandrasekaran
Hi Ian,
I have tried running the original file with MPP version 14. I get the following
Could you please share an image of the hull deformation results that you obtain.
The material is modelled as steel with a thickness of 0.2m (20cm). The fluid is water and the fluid inside is an arbitrary fluid with half the density of water. In any case, such a thick hull cannot deform due to the fluid.
Similarly by only changing the material behaviour in the original file, changing the material for PART=5 (lagrange shell)  from ELASTIC to RIGID, the results are completely unrealistic.
In the original model, the node set of the lagrange part 5 (ship) is only constrained from moving out of plane. So Ideally the wave must be able to move the structure in the X and Y directions. Instead, the part remains fixed in space. Could you please explain if I am missing any details in this model.
Thanks & Regards
Abhemanyu
