Ansys Learning Forum Forums Discuss Simulation LS Dyna Metal forming (spinning) Reply To: Metal forming (spinning)
Reno Genest
Hello Zhao,
It is okay that the speed is fast in the experiment. We need to keep the same speed in the simulation and troubleshoot the problem :).
Plot the internal, hourglass, and sliding energy together on the same graph without kinetic energy. What does it look like? Please post a screenshot.
Also, check the RCFORC (contact force) between the blank and the  wheel and compare between case 1 and 2. If the contact is the problem, the contact force should be much larger in case 2.
Reno.
