Ansys Learning Forum Forums Discuss Simulation LS Dyna Metal forming (spinning) Reply To: Metal forming (spinning)
Reno Genest
Hello Zhao,
The sliding energy and contact force should indicate if the contact  is the issue or not. If the contact  is the issue, try the following:
  • I don't have much experience with forming contacts. But, I would try SOFT=2 (segment based contacts), SBOPT=3, and DEPTH=35. If it does not work better, try the *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE with these settings instead.
  • Reduce the bucket sort frequency.
  • Reduce TSSFAC
Let me know how it goes.
Reno.
