Ansys Learning Forum Forums Installation and Licensing Ansys Products Why is Two-Way Coupling in Ansys Icepak-Maxwell not supported for Transient? Reply To: Why is Two-Way Coupling in Ansys Icepak-Maxwell not supported for Transient?
sbacus
If you are dealing with joule heating, I would recommend using Icepak's joule heating simulation. This method has been proven to be highly accurate, as we have validated it through experiments and hand calculations.
From my investigation, it seems that the two-way coupling method in AEDT is currently not defined for transient mode, as I mentioned in my previous post. You may refer to that for more information.
/forum/forums/topic/in-2-way-coupling-how-we-can-identify-the-correct-value-of-coupling-iteration/
