Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Hydrostatic Equillibrium and material deformation in S-ALE FSI › Reply To: Hydrostatic Equillibrium and material deformation in S-ALE FSI
May 23, 2024 at 6:41 pm
Ian Do
Hi Abhemanyu,
Can you list out exactly which KW you modified and how were they modified?
During the conversion, please make sure you check:Â (IC = initial condition, BC = boundary condition)
- unit system used
- mat data - check EOS (IC) input & the resulting P0(t=0), rho0(t=0) in all ALE fluids
- IC's BC's - vel(t=0)Â
It looks like there may be something wrong in the input that causes the strange ship hull deformation(?). You can try:
- go back to run the original model (no changes)
- then convert 1 KW at a time and rerun
- This will pin down exactly which change may cause the strange result.
Hope this helps.
Ian Do, PhD
