Ansys Learning Forum Forums Discuss Simulation Photonics Regarding the Farfield simulations and placement of monitors Reply To: Regarding the Farfield simulations and placement of monitors
Amrita Pati
Hi Prabha,
Keeping the monitor half a wavelength away from the PML is not based on an exact equation but more of a rule of thumb for most simulations. I will recommend placing it about 1 um away. In the 2nd screenshot, it looks like the monitor is in the PML, so I am not even sure if it is recording the fields. If you do not see any difference between the 1 um and 2.5 um, then I will recommend using the first as you can same time and resources simulating a smaller simulation domian.
Amrita
