Ansys Learning Forum Forums Discuss Simulation Photonics question about getting the Barry phase as a function of the rotational angle Reply To: question about getting the Barry phase as a function of the rotational angle
Amrita Pati
Hi Carloso,
I believe the s-params analysis group would only work for s and p-polarized inputs and outputs (Metamaterial S parameter extraction). As you can see in this older post: How can I calculate s-parameter of circular polarization source? It seems that you either have to modify the code in the analysis group to incoporate both components of the fields or calculate the S parameter from the first principles. Let me see if there is a simpler approach for obtaining the phase, I will come back to you soon.
Amrita
