Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Specifying memory mode from the command line? › Reply To: Specifying memory mode from the command line?
mrife
David
Well remember the command line -m is the initial allocation; MAPDL still can do dynamic allocation from there.  Are you a commercial customer (I'd like to see the output file)?  Also the value can be set to a negative number to force using a specific amount (and so turning off dynamic allocation).  The -db size, which can also grow dynamically, is taken out of the -m amount.
