Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Number of cores used › Reply To: Number of cores used
Devendra Badgujar
The student version doesn't support this, so it will run on the default included 4 cores (or less) but it will not use more than 4 cores. You can set the use solver default for Max number of processors in File>>Settings>>Physics.
Thanks,
Devendra
