Ansys Learning Forum Forums Discuss Simulation Photonics Script element in Lumerical interconnect Reply To: Script element in Lumerical interconnect
GWANG
Hi Pranat Panda,
Thank you for the post. As for your questions:
  1. To get start with INTERCONNECT I recommand the ALH course: https://ansysinc.plateau.com/learning/user/deeplink.do?linkId=ITEM_DETAILS_FOR_SAME_REVISION_OF_ITEM&componentID=Lum_INTERCONNECT_GS_2020R2_SP&componentTypeID=MOD-ONL&fromSF=Y&revisionDate=1608554595000&hideItemDetailsBackLink=Y&seqNumber=1854568&_s.crb=Nl6xlUCRWBgKEJG65jDmeMC6GmIp2PThdYD31I375fA%3D#/53FE8353D31AA86517002C00D57C0015
  2. There are multiple ways to model a waveguide in INTERCONNECT with FDE simulation results.For your model, do you mean you fix the operating wavelength of the waveguide and sweep through the waveguide width? In that case you can use the scripted element in INTERCONNECT to set the s-parameter; or you can use a compound element that contains a Straight Waveguide model, and set the neff value to the Straight Waveguide based on the waveguide width parameter. The second method is probably easier in this case.
Hope this can help.
