Ansys Learning Forum Forums Installation and Licensing Ansys Products ANSYS NOT WORKING- WORKBENCH UNDER ANALSYSIS Reply To: ANSYS NOT WORKING- WORKBENCH UNDER ANALSYSIS
Mrunali Barde
Hello Shubhi,
Close all the Ansys applications before trying the below suggestion step by step.
Can you please try adding the below timeout features in the ansyslmd.ini file –
Go to C:\Program Files\ANSYS Inc\Shared Files\Licensing directory, copy the ansyslmd.ini file to the desktop location.
Open the ansyslmd.ini file using Notepad and add the following lines –
ANSYSLI_FNP_IP_ENV=1
ANSYSLI_TIMEOUT_FLEXLM=20
ANSYSLI_FLEXLM_TIMEOUT_ENV=20000000
ANSYSCL_TIMEOUT_CONNECT=60
ANSYSCL_TIMEOUT_RESPONSE=300
Once you add the lines, click Save As > ensure that the save as file type is ‘all files’.
Once the file is saved, please replace the old ansyslmd.ini file using the newly created one.
Also set the following Environment Variable –
Go to START > Search ‘Edit the System Environment Variables’ > Click Environment Variables.
Under the System Variables, please click NEW and create a new variable.
Variable Name – FLEXLM_TIMEOUT
Variable Value – 60000000
Save it. Relaunch Workbench.
I hope this helps,
Wishes, Mrunali.
