Ansys Learning Forum Forums Discuss Simulation General Mechanical What is the ideal way of applying cyclic loading? Reply To: What is the ideal way of applying cyclic loading?
dlooman
If you want the steady state response to a long duration cyclic (sinusoidal) loading you can do a harmonic analysis and simply specify the frequency of the cyclic loading in Hz.
