Ansys Learning Forum Forums Discuss Simulation Fluids Divergence detected in AMG solver: pressure correction temperature limited to… Reply To: Divergence detected in AMG solver: pressure correction temperature limited to…
The problem is liquid enters at a set rate and if it doesn't evaporate can't leave. The solver then struggles and fails. You need to rethink the set up.Â
