Ansys Learning Forum Forums Discuss Simulation Fluids Divergence detected in AMG solver: pressure correction temperature limited to… Reply To: Divergence detected in AMG solver: pressure correction temperature limited to…
S.Shrestha-4
Yes, there is constant heat flux at the bottom wall. How do you initialize the domain with water when it's running through the channel? Do I patch domain after initialization with water volume fraction = 1? I will try with this.
And since no water is allowed to exit the outlet, would it completely vaporize after some time?Â
