Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The flow from the inlet did not pass through the golf ball in the rotating domai › Reply To: The flow from the inlet did not pass through the golf ball in the rotating domai
May 22, 2024 at 12:33 pm
You can turn off the spin! The pathlines follow the flow, so it looks like there is a 3d effect too if you look at where they finish up.
