Ansys Learning Forum Forums Discuss Simulation Fluids Divergence detected in AMG solver: pressure correction temperature limited to… Reply To: Divergence detected in AMG solver: pressure correction temperature limited to…
And vapour is being added where? If the outlet is 5 bar (gauge) the inlet will be a higher pressure to push the set flow in, but that may take an iteration to pick up.Â
