Ansys Learning Forum Forums Discuss Simulation General Mechanical ERROR: A general failure occurred during the solution process. Reply To: ERROR: A general failure occurred during the solution process.
asustark700
Namastey sampat bhaiya,
Thanks for your response first.
  1. YES, I did encounter the failure when i clicked solve button.
  2. I checked the propeller in repair tab in spaice claim, got some errors (exact edge, simplify).
    • but failed to solve.
  3. I tried global as suggested and different methods but failed to generate mesh.
This drone propeller is thin, could you please suggest the way to get sucsseful meshing or anything watching the model.
DOC: Propeller step file
POV: you are taking to a begainner.????
