Ansys Learning Forum Forums Discuss Simulation 3D Design airflow valve problem with solids Reply To: airflow valve problem with solids
kasper haack
Hi Devenda
The air is passing strait through the bottom part even its defined as a solid and as an component in the model tree.I can select it and move it etc.
The image is at the top of the tread, its supressing the geometry by some reason, a have atached the .sat and the discovery file at the top in the sharepoint link.
Iam not getting any errors in Discovery when geometry is checked :/
Best Regards
Kasper
