Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Divergence detected in AMG solver: pressure correction temperature limited to… › Reply To: Divergence detected in AMG solver: pressure correction temperature limited to…
May 21, 2024 at 5:31 pm
I did hybrid initialization and did a patch afterward with water and vapor volume fraction = 0. At the inlet I set, water volume faction = 1 and vapor = 0. Could it be that I set pressure outlet at 5 bar? What pressure inlet would fluent set? I used velocity inlet, so there was no pressure inlet input.
What other initial conditions should I set and where?
