Ansys Learning Forum Forums Discuss Simulation 3D Design Chamfer with Variable Radius Round Corner and Straight transition? Reply To: Chamfer with Variable Radius Round Corner and Straight transition?
Atharv Joshi
Hi Gerry,
You can use the approach of moving the lower magenta colour dot from 100% to 0%. I will see if there's any simple option to apply straight transition.
Thanks and Regards
Atharv
