Ansys Learning Forum Forums Discuss Simulation Fluids Divergence detected in AMG solver: pressure correction temperature limited to… Reply To: Divergence detected in AMG solver: pressure correction temperature limited to…
The calculation will start based on what you set for the initial conditions: that's something you need to check. With VOF you can only specify one or other phase on the inlet boundary.  Micron scale may be OK, it depends on how many microns you're using. However, the mesh resolution necessary may be far more than you have set.
