Ansys Learning Forum Forums Discuss Simulation Platform How to run Optislang and Ansys Workbench on HPC Reply To: How to run Optislang and Ansys Workbench on HPC
Markus
 Hi C.Bruno,
thanks for your response. I have to admit, but I can not give you detailed guidance within scope of the forum. Sorry.
I can just outline a possible way:
1) creating the necessary fluent files with the Workbench node under WIN,
2) then adding a PuTTY/SSH node, sending the fluent files and execute the simulation under LIN (using a .sh file) and writing the necessary information in a text output file,
3) use the same PuTTY/SSH node to receive this output file and
4) add an ETK node to the workflow to read the results of the file.
You see, getting your workflow running needs adjustments of your workflow and may also involve IT configuration e.g. of an existing password-less login (named under “System Requirements” in PuTTY SSH, PuTTY SSH (ansys.com)).
I would consider also other approaches, if possible, e.g. avoid working cross platform.
If you have access to support, you may can create a support case for a detailed discussion.
If not, maybe other forum members can contribute in the future.
Best regards,
Markus
