Ansys Learning Forum Forums Discuss Simulation Fluids Non-uniform input boundary condition. Reply To: Non-uniform input boundary condition.
SRP
You can use an expression to apply variable boundary condition. You can check user's guide: 5.3. Creating and Using Expressions (ansys.com)
If you want to change the expression after specific time, you can use the conditions like 'if' while creating an expression.
Hope this helps.
