Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Analysis Result Export › Reply To: Analysis Result Export
Akshay Maniyar
Hi Jeone,
The only file format available for export from Mechanical is.STL. In order to clean and build the solid from the faceted geometry, you will need to import it back into SC. You can then export in the desired format, such as stp or Parasolid, after that.
Thanks,
Akshay Maniyar
