Ansys Learning Forum › Forums › Discuss Simulation › Fluids › FENSAP-ICE Viewmerical Batch mode › Reply To: FENSAP-ICE Viewmerical Batch mode
May 21, 2024 at 6:20 am
To save Ice Thickness using Viewmerical in batch mode, you would typically need to know the specific field code or set up an equation if a code is not available. Unfortunately, based on the information provided we’re not able to provide specific details about it.Â
Hope this helps - ANSYS Fluent: Postprocessing Using Viewmerical and CFD-Post with Fluent Icing - Ansys Knowledge
Thanks!
