Ansys Learning Forum Forums Discuss Simulation Fluids Report the drag/lift force on particles in DPM Reply To: Report the drag/lift force on particles in DPM
lec chen
Dear Rob,
Thank you so much for your kind reply.
1- When i build the UDF in compiled UDFs, the console has reported
{ scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly. File "F:\05 DPM model\libudf\win64\3ddp_host\SConstruct", line 20, in
scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly. File "F:\05 DPM model\libudf\win64\3ddp_node\SConstruct", line 20, in . Compiler path: xxx. Linker path: xxx.
scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly. File "F:\05 DPM model\libudf\win64\3ddp_node\SConstruct", line 156, in . C sources: ['track_forces.c']. lld-link: error: undefined symbol: P_DRAG
>>> referenced by track_forces.obj:(track_forces)
lld-link: error: undefined symbol: P_SAFFMAN_LIFT_FORCE
lld-link: error: undefined symbol: P_VIRTUAL_MASS_FORCE
scons: *** [libudf.dll] Error 1}
2- When i load the library, the console has reported
{ERROR: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64). ���������������������
F:\\05 DPM model\\libudf\\win64\\3ddp_node\\libudf.dll. Error: An error occurred in the previous operation. The details can be found in the text output.
Error Object: #f }
3-  Your suggestion to use the current version of the manual is very helpful. However, as I am new to UDF in Fluent, I need to spend more time solving the problem and reporting the drag/lift forces on particles in DPM.
Thanks
