Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Set Thread Variable Error when running in cluster › Reply To: Set Thread Variable Error when running in cluster
uddin43
Thank you Rob. The issue was with version. I was using a higher version of Ansys locally and changing my version worked properly. Thank you for your time and support.
