Ansys Learning Forum Forums Discuss Simulation Fluids Set Thread Variable Error when running in cluster Reply To: Set Thread Variable Error when running in cluster
There's nothing in the model that should cause a problem. Have you tried running on fewer cores?  Which version are you running on?
