Ansys Learning Forum Forums Discuss Simulation Fluids Set Thread Variable Error when running in cluster Reply To: Set Thread Variable Error when running in cluster
uddin43
I understand it is a conformal mesh. In local ansys both conformal and non-conformal is working. In cluster, without activating energy equation, it is working fine. However when energy is activated, its not working. I am using 1 node 32 cores for the cluster. The parallel settings are mentioned in the bash file attached above.
