Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Set Thread Variable Error when running in cluster › Reply To: Set Thread Variable Error when running in cluster
That's not a nonconformal interface, it's a conformal coupled wall. There's nothing in the journal that could be causing a problem, can you run on the cluster via GUI? What parallel settings are you using, and how many cores?
