Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Set Thread Variable Error when running in cluster › Reply To: Set Thread Variable Error when running in cluster
uddin43
Yes, it is working fine locally and providing results with non-conformal mesh also. However, I need to run this on cluster. Any more suggestion?
Outlets are simple pressure outlet with guage pressure 0 and walls are no slip walls with 0 heat flux.
