Ansys Learning Forum Forums Discuss Simulation Fluids Set Thread Variable Error when running in cluster Reply To: Set Thread Variable Error when running in cluster
Looks OK. Can you initialise & run locally?  Check the other wall boundary settings, and what is set on the outlets.
