Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Defining fluid domain › Reply To: Defining fluid domain
chiheb ben abdallah
Thank you Rob,
I'm having trouble defining the fluid domain to simulate the air flow initially going inside the exhaust then recirculating and moving around the exhaust and going back in the  intake of the exhaust (rectangular surface) +I don't know how to define and modify or delete interiors, walls,inlets and outlets in  solution mode can you help me with that
Thank you
