Ansys Learning Forum Forums Discuss Simulation Fluids Set Thread Variable Error when running in cluster Reply To: Set Thread Variable Error when running in cluster
uddin43
Hi Rob,
My actual problem is a shell and tube heat exchanger. But for finding the error, I simply generated the following cube setup. All the boundary conditions are shown in the below picture. I am also sharing the journal and shell files I have used. As I said, in local ansys the simulation is running with no errors, but the cluster is showing the error just after reading the boundaries, I have also attached the image of that. Kindly help.
