Ansys Learning Forum Forums Discuss Simulation Fluids FSI simulation of ascending aorta Reply To: FSI simulation of ascending aorta
Possibly - monitor the inlet flow rate, zone volume and outflow rate over a cycle and see what the numbers tell you. You'll need Excell as you need the difference in value between time steps. Note, you can get a reverse flow warning but have a net outflow if only small parts of the outlet are affected.Â
